woot victoria FTW!!!
(the rules are probly the same though.....)
Standard rims FTW!!
This does suck majorly, sorry to hear about that Neil
Good info though .......
Ah manWhen was this Neil, and where? Did they just pull you over specifically for that?
Dont look down upon it Neil, wear it like a badge of honour hahaha.![]()
So let me get this straight, the tyre width can't be more than 26mm wider than stock, but there is no restriction on the size of the rim itself (so long as I match it with a low enough profile so as not to have the whole thing wider than 15mm from stock...
So I can go from 15" rims with a 4" profile tyre for a total of 19" of diameter to say a 18" rim as long as I can find a 1" profile tyre right?
*Numbers are made up for argument sake.
And that also means that for a VR6 who standard wheel is 6" / 6-1/2" wide you can only run a 7" - 7-1/2" tyre.
In other words, the law doesn't care if you want to run 20" rims with rubber painted on the outside, the problem is that they are too wide?
talking diameter here not width.
sounds about right. believe the diameter issue is around your speedo accuracy. most tyre places when you ask for replacement wheel/tyre combos will do the calc for you so that it minimises the impact on your speedo.
1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
No, the tyre can be wider than the 26mm. The 26mm applies to the rim width.
26mm wider rim without the need of an engineers certificate.
You can go wider but you need an engineers certificate and these rules apply:
Up to 800kg = 26mm wider than factory
801 - 1200kg = 37mm wider than factory
1201kg up = 51mm wider than factory.
This has to *also* correspond with the speed and load ratings of the original tyre. So, if the originals are 95Y where 95 = 692kg and Y = 300kmh then you must fit tyres that are equal or better than these ratings. If the replacement tyre rim package fit the above criteria, then theoretically, yes you can do what you have suggested.So I can go from 15" rims with a 4" profile tyre for a total of 19" of diameter to say a 18" rim as long as I can find a 1" profile tyre right?
No, the *rim* can only be 26mm wider *than the largest optional rim width that comes as standard with that vehicle*, but the tyre can be wider than the 26mm allowable for the rim. So, the largest optional rim width for your car maybe 7" rims with 215 width tyres and you can opt to go aftermarket to 8" rims but you can go to 245 width tyres, which is a 30mm difference in the tyre width.And that also means that for a VR6 who standard wheel is 6" / 6-1/2" wide you can only run a 7" - 7-1/2" tyre.
You can run 20" rims as long as they are no more than 26mm wider than the original rim width and that the overall diameter is no more than 15mm bigger (or smaller).In other words, the law doesn't care if you want to run 20" rims with rubber painted on the outside, the problem is that they are too wide?
