Results 31 to 35 of 35
Thread: wheels for my MK1?????
  1. #31
    Aug 2009
    Torquay, victoria
    i really want some of you guys feedback on these wheels i posted up above good value for the dollars?? would they be easy to polish?? i think they would suit but i value u pro dubbers opinions, so help me out.
    http://cgi.ebay.com.au/ROH-AERO-allo...#ht_500wt_1182
  2. #32
    Jun 2009
    I think they would look good, the little holes would be a bit of a pain to clean but just hit it with wheel sealant and it should be fine
    They do suit the older style of the car and could even have the centres coloured.
  3. #33
    Jun 2007
    Eastern Suburbs Melbourne
    look through the rat and retro thread, there's more than a couple cars with zender turbo's on, these wheels should look pretty similar.
    infact, I did a bit of serching and found a mk 1 on this site that once wore the same ROH style wheel!
    http://www.vwwatercooled.org.au/newf...=zender+turbos
    i like volkswagens
  4. #34
    Aug 2009
    Torquay, victoria
    help with wheel size..... will these fit the mk1
    4x100 15x6.5 ET38
    or would i need some sort of spacer?
    cheers
  5. #35
    Jun 2007
    depends if you are going to lower it with coilovers or not. they *should* fit with normal suspension, but probably only just fit with coilovers. i'd suggest you'd need a spacer if you were to run coilovers. just have to worry about centrebore and brake caliper clearance.
    infact, have a look here, and through the rest of the wheels and suspension & mk 1 sections, all the info is already there.
    http://www.vwwatercooled.org.au/newf...ad.php?t=33837
    i like volkswagens
