Results 1 to 7 of 7
Thread: Which wheels? Decisions, decisions, decisions!
    Oct 2011
    St Kilda Road, Melbourne
    Has anyone got any advice/opinions on what wheels I should throw on my mk1? I want my golf slammed to the floor and on 13's, was thinking some deep dish 13x7's, but how much arch work will be needed? Plus I want stretch look for the tyres but don't want to spend a million $'s!
    What sizes should I be looking at?
    Thanks in advance guys!
    stretching tyres don't cost any more then normal unless you get weird sizes.
    if you want 7s you need to work out your offset. width alone means nothing...
    Then once you have the offset, im sure some of the mk1 guys could tell you what size tyres you will need to clear guards etc
    Oct 2011
    ET-7 is the offset on the wheels I've been looking at. Unsure of the arch work required to get them to fit. I'm going to be getting coilovers that lower 120mm and I was hoping to run them as low as they will go with those wheels on.
    Jul 2005
    Newcastle, NSW
    7" with -7 offset is about 20mm more poke than a normal fitment 15" which is about -28.
    I'd imagine without some guard work your not going to get them on and that low as the guards don't have the width required.
    I run 7" -28 with a 10mm spacer on rear and (ie. -1 and it's 'close' to the guard when low.
    But I could be proven wrong.
    Quote Originally Posted by mikinoz View Post
    you mean your running 7"et18 mikinoz? not et-18...?
    Jul 2005
    Newcastle, NSW
    Probably, I was not really using et, more simply the measurement from centre. I was of the understanding towards the outer lip was negative and the inner positive?
    All the same, the wheels are et28 with a 10mm spacer to et18 then I'd assume based on the above.
    Sorry of I have confused anyone.
    Oct 2011
    Offsets always confuse me! Im going to get them ordered I think and just make them fit! Any ideas on tyre size and availability for that stretched look? The 14x6's I've got for sale at the moment are a nightmare to get small tyres for here, in Europe no problem! Stupid Euro sizes!
