wheel solutions in richmond?
Can anyone recommend a wheel specialist in the Melbourne area. I'm located in the western suburbs. I have inherited a set of wheels and need them looked at to see if they're good or if some repair work is needed. I was told one of them did have some damage but I'm keen to see if they can be repaired. If it can't be repaired I need a specialist who might be able to source a replacement. I've scoured the internet and not found one myself. Fingers crossed I can get them tested and repaired
I've have been given a company in Bacchus Marsh called Wheels but its a fair drive. I'll go there if there's no better suggestions
Any recommendations would be greatly appreciated
Yep, if it can be saved, Matt and Andy will get it sorted.
Wheel Solutions isn't cheap but the work is top notch
Resident grumpy old fart
100% agree - they repaired a wheel for me last year and were spot on with their work.
Nice one, thanks for the replies. Quality is what i'm looking for so Wheel Solutions it is
Dropped off the wheels at Wheel Solutions yesterday. Matt's able to fix the damaged wheel and I'm having them painted black with diamond etched centre and rim. I've attached the wheels as they are and will send photos of the finished product.
Great advice lads, Matt was brilliant. I gave the forum a plug also
