Results 11 to 20 of 21
Thread: Wheel Spacers, Good or bad idea?
    Jun 2006
    Orange NSW
    Quote Originally Posted by thezoneR32 View Post
    Thats interesting! Goes to show, who would know what is oem and what isnt?
    Pretty much.
    Thanks fellas, this is the bit I'm confused about, where do the bolts go? If I pull my wheels off, there are bolts sticking out of the hubs?
    there are two types, some you can get will bolt the spacer to the hub, and then either via studs or a second set of bolts the wheels are bolted to the spacer. This is generally the setup used on adapters where PCD is converted.
    Then there is also just the spacer and longer bolts (which will probably be for you)
    These will often come with two sets of holes (mine have 5x100 and 5x112) so with one set of extended bolts they can be used on different cars (and makes them easier to sell later on...)
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Nov 2009
    Thanks for that, will have to rip my wheel off again and have a good look so I know exactly what to order.
    Volvo S60 RD T6
    Apr 2011
    Brisbane Australia
    On your R32??
    2010 Golf R 5 dr , Black , DSG , Leather and 8.5x19 ET50 AZEV Type R
    Nov 2009
    Quote Originally Posted by LWR View Post
    On your R32??
    Uh sorry my bad.
    Volvo S60 RD T6
    Nov 2009
    Does anyone know where else I can get H&R 20mm DRA spacers They're on back order at ecs! Volkswagen R32 MKV 3.2 > Wheels > Spacers > HR > ES#5111 DRA Series Wheel Spacer - 20mm (1 Pair) - 40555712
    Volvo S60 RD T6
    Nov 2009
    Can anyone tell me why the ecs spacers are dearer than the same product from H&R?
    Volvo S60 RD T6
    May 2009
    North Brisvages
    I wonder what the go is with regards to the legality of running adapters. As it's actually bolted to the hub and thus therefore should become part of the hub assembly when fitted. Then your wheel bolts to this hub assembly, no "spacers" used !.
    Jun 2006
    Orange NSW
    Quote Originally Posted by Big_M View Post
    I have a feeling adapters are legal but spacers are not. Don't quote me on that, though.
    May 2009
    North Brisvages
    Anyone know the legalities for bonnie QLD ?
