I'm buying an 09 Passat V6 4 motion highline, haven't driven it yet though, it's getting shipped over from Vic. How is the standard suspension? Is it only the r36 that gets the sports suspension? What would it cost to upgrade (roughly)..
Congrats on the new ride.
From memory, the V6 4Motion Highline gets an 'in between' suspension, coupled with Adaptive Chassis Control as standard. The ride height from memory is about 15mm lower than the 4-cyl Passats (R36 is 25mm lower). From what I have read, having the ACC set to 'sport' gives a ride quality similar to that of the R36. Drive your new car for a bit first, then decide whether you really need to upgrade the suspension.
According to these VW specs, in MY09, the Adaptive Chassis Control (not to be confused with Adaptive Cruise Control) was fitted as standard exclusively to the 3.2L V6 Highline, the R36 got the 25mm lower sports suspension, and all the other models got 'regular' suspension.
MY2009 specifications
For MY10, ACC became available as an option across the Passat range, but was only fitted as standard equipment for the 3.2l V6 Highline. The 3.2L also got 15mm lower suspension, and the R36 suspension carried over.
MY2010 specifications
ACC is independent to stability/traction conrol, as it operates on the suspension, and on the steering. There's a good explanation of how it works in the glossary section of the spec documents linked above.Is ACC similar to stability control/traction control systems?
great thanks
Depends on what sort of roads you normally drive on. If it is smooth highway kind of roads, the R36 suspension is good. However, in Melb where i'm from, driving the R36 in the inner city suburbs is quite a pain as the suspension is pretty stiff for this sort of car.
Mind you, i came from an evo 9 with aftermarket suspension. -.-
