Results 1 to 10 of 11
Thread: Wheel pcd adaptors
    Dec 2006
    sorry guys e/t is 15
    Quote Originally Posted by seangti View Post
    The price of the car rarely indicates driver ability/lap time.
    Jun 2007
    Eastern Suburbs Melbourne
    Quote Originally Posted by jasn78 View Post
    well that makes it et -5 to et -10. they won't work.
    i like volkswagens
    Dec 2006
    jared, sorry mate not following wont spacers/adaptors make for more room or are u saying thats the problem?
    Jun 2007
    i'm saying the offset with the adaptors, which you need to fit the wheels on, will push the wheel out past the line of the gaurd. because it has such a low ET. negative infact.
    standard gti wheels have ET38-45, to give you and idea, these wheels you want would end up havng an ET-10 [roughly]
    spacers are good if you have high ET's to make the wheel sit further out, or you need them so as to push the wheels out to clear large brake calipers.
    i like volkswagens
    Nov 2005
    dunno if you can tell by this drawing i just made, just it gives an example of how the adapters will affect the wheel
    the inner left rectangle is the hub on the car, the red rectangle attatched to it is the adapter
    the big black square is your wheel before the adapter and the red one is what will happen once you add an adapter
    dom
    Dec 2006
    thanks guys that was useful well dom guess i cant copy ur idea of fuchs for the polo fudge it
    Sep 2007
    when you have a lowish offset, ie <et25, depending on the wheel width, it will most probably stick out waaayy to far from the guard.
    the adapter has to accommodate the wheel lugs and for structural integrity, they dont really make them less than 15mm thick. if you're using an offset calculator like 1010tires, the addition of an adapter will directly add to the offset - eg, 7 inch wheels with et 20 (20mm + offset), with 20mm adapters will equate to an effective offset of et 0. this means your wheels will stick out 20 extra millimeters.
    5x130 are usually porsche wheels which *usually* have a super high offset. you can get away with adapters for these because something like et 50 with a 20mm adapter only equals et30 which is quite fitting for a polo
    87' MK2 GTI
    13' MK7 TDI
