Results 1 to 9 of 9
Thread: Wheel bolts
    Mar 2013
    Act
    Wheel bolts
    Hi there, this is more for those who have fit japanese wheels to a early german car.
    Im in a pickle with how to mount my wheels to the car as the bolts i need are meant to have a sleeve insert sort of thing to keep them from moving around when mounted and as far as i know there are no bolts that have the sleeve to do that. any help?
    But no really, I like to look distinguished when I step out of the car. People are like, "wonder what he does for living."
    I just reply, "your daughter, sir." - some dude on stanceworks
    I had fixed half the broken crap but that just meant it was still halfway inoperable
    When you say jap wheels what do you mean. 4x100 or 4x114 or 5x100 or 5x114 or one of the other sizes?
    What pcd is the car?
    Mar 2013
    Act
    4x100, for a mk1 golf. i dont know how to explain what i mean properly and it sucks hahaha
    Guessing you mean you need conical/after market bolts rather then oem/ball seats then?
    Mar 2013
    Act
    Shanked wheel bolts are what i need, thats what the sleeve i was talking about is
    Erskineville, NSW
    If I've understood correctly...
    You either have to convert your hub to studs & use shanked / sleeved nuts
    or
    get shanked nuts & locktite a threaded section into them
    or
    Find somewhere to supply these (speedshack in the UK have them). They call them a sleeve bolt.
    http://www.speedshack.co.uk/images/S...x1.5%20lge.jpg
    Oct 2010
    Melbourne, VIC
    Resident grumpy old fart
    May 2012
    when i fitted SSR's to my mk2 i bought studs loctited them in and then bought SSR shank nuts from japan.
