Results 1 to 9 of 9
Thread: wheel bearings
    Aug 2006
    wheel bearings
    If my front wheel bearings were stuffed... does it make noise when im driving straight??
    as my wheels spin, it makes a noise
    is it a expensive part aswell??
    Dec 2007
    Ermington, Sydney
    Yeah that sounds like your wheel bearing dude. It's a really annoying, constant noise (I've got it on the rear wheels haha). I got my wheel bearings from GAP for my car for like....15 each or something insanely cheap like that. The fronts are more expensive, but I don't think they were more than about $28 ea from GAP as well.
    Aug 2006
    awesome!! where is GAP?
    Jan 2008
    Cremorne, Melbourne
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
    Sep 2007
    you have to press the front bearings in and out.. it'd be easier to take them somewhere not insanely expensive and have them do it. they cost like 40 or 50 per side from tooleys imports up in hornsby. much easier to get them from here.
    maybe your buckled rims are contributing to it..?
    87' MK2 GTI
    13' MK7 TDI
    Suffolk UK
    You know its a bearing when you have a loud whiring noise, mine sounded like a helicopter when it had gone. As you are going around a corner you'll find as the weight is all on one wheel the noise stops.
    Aug 2006
    Quote Originally Posted by carpoid View Post
    yep!! same noise.. i thought it was my buckled rim.. and i put all my stockies bak on and same noise..
    Jul 2005
    Newcastle, NSW
    Quote Originally Posted by jayjay View Post
    Buckled rims cause bearing failure is what Jay is trying to say. Don't put buckled rim on once you have the new bearings...
    Aug 2007
    Camden, NSW
    My dad changed both right and left front wheel bearings on his VR6 for $70 each from Repco. Did them himself, made the tools he needed, took about 3 hours each side. Turns out it was the front right wheel bearing that had a faulty ball in the bearing which had delaminated.
    He got the info he needed from here:
    http://forums.tdiclub.com/showthread...wheel+bearings
    and here:
    http://forums.vwvortex.com/zerothread?id=1722551&page=3 (part E has to be 72mm OD not 73mm OD for the VR6 otherwise it wont fit in the hub when you push the bearing back in)
    03 MkIV GTI - K04-001, APR 2.5" TBE/TIP/Software, Forge FMIC, GFB DV+, Powergasket+, Dark Tint, 17" Bora Sport, Bilstein shocks, Eibach springs, BMC CDA, Dieselgeek SS, Hella Celis, R32 Alloy Trim...
    95 MkIII VR6 (sold)
