Thanks Preen,
I made the jigs up just to get better access to everything, I found setting the camber solo pretty hard with the wheels on the ground because I couldn't watch the gauge and be 1/2 under the car with a socket on the strut bolts. Jacking it up wasn't the answer because I needed weight on the suspension. The car is 30mm lowered so there's's not much room to work around the tyre. There's a little refinment needed but this method works for me.
Pete
