Results 1 to 5 of 5
Thread: Wheel Adaptors
    Apr 2006
    Ashfield NSW
    Wheel Adaptors
    Has anyone used wheel adaptors to convert 4 stud hubs to 5 stud. Do they simply bolt on the existing hub? Or is it just better/cheaper to re-drill the wheel to fit? All the wheels i fancy are 5 studders an its pi##ing me off!
    Cupra 20VT
    sydney
    h&r make some tuv approved stub adapters i run them on my old car to fit porsche wheelsthey bolt onto the hub and the wheels bolt to them. there are several other copanies that make them just keep in mind the final et you are looking for, as most adpter will be 25mm thick
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
    golfie_boy Guest
    wat wheel
    well depend on the wheel u want to put on wat the offset is and the j size i had 2 of my cars drilled 5/100 if u use an orignal audi or vw wheel the wheel generally clears for the centre bores are the same but depends on the wheel all 5/100 vw audi wheels centre bores and the same i had a 17`/7,5j audi tt wheel on my mk1
    another option is if the pcd of the wheel is covered u can get the holes closed and redrilled 4/100
    we used to do that in south africa my friend owns a wheel shop i put a ford fiesta st150 wheel on a mk1 i owned
    Oct 2005
    you can get wheel adaptors but they are technically illegal here in NSW
    \'95 Golf VR6
    May 2006
    byron bay area
    i think the easiest & cheapest way is to buy new hubs & have them redrilled to suit
    you bolt the new 4 hole hub to the 5 stud wheel in 1 hole as one hole will line up,
    that shall act as a piolet guid to drill through the existing bolt hole in the wheel & then staight through the hub to make another 4 holes in the wheel
    then fit new rear discs that are a 5 stud fit
Similar Threads
  1. Wheel Fitment Guide
    By WABIT in forum Wheels & Suspension
    Last Post: 11-01-2009, 12:56 PM
  2. mk3 - wheel alignment done myself
    By golfvr6 in forum Mk3 Golf & Vento
    Last Post: 10-01-2007, 09:00 AM
  3. Hollow MKV Rims from BBS
    By mikinoz in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 29-05-2006, 06:47 AM
  4. Set wheel alignment for free
    By imported_brackie in forum VW Watercooled Media Lounge & Interesting Articles
    Last Post: 13-05-2006, 01:47 AM
