Hey guys,
After some advice.
I have recently fitted some BBS RS to my Mk2 golf, which required redrilling from 4x114.3to 4x100 and required hubcentric rings to fit (57.1mm to 67mm)
The wheels are 15x6.5 +17mm. I am quite happy with how well they sit on the front of the car, but would like to bring them out a litte more on the rear to keep them 'flush' all round.
Basically what i want to know is; what is the best option/ type of spacer to use?
If i use a hubcentric 57.1 mm centrebore spacer for example, the hubcentric rings wont fit over the chamfer of the spacer? I dont think anyway..
And if i decide to use a bolt on spacer, im pretty sure minimum thickness is 25mm or so to clear the heads of the lugs bolts, where i was hoping to go for about a 15mm spacer.
Any suggestions would be awesome.
Cheers.
