Results 1 to 8 of 8
Thread: What would cause this damage?
    Jul 2010
    Elanora Heights, Sydney
    Hi All,
    I went to change my strut top and bearing today when I discovered there was a bit more damage than I expected to see.
    What I'm wondering is, what would cause this? Maybe over tightening?
    What would cause this damage?-20160806_151105-jpgWhat would cause this damage?-20160806_151059-jpgWhat would cause this damage?-20160806_151041-jpgWhat would cause this damage?-20160806_151029-jpg
    Thanks guys,
    Christian
    Jul 2010
    I don't know why they're upside down... They're perfectly upright on my machine.
    Were they new when installed, or previously on other suspension?
    Jul 2010
    Hi Dylan.
    The spring cap is original i believe. The strut tops and bearings were replaced within 20k ago.
    Sent from my SM-G920I using Tapatalk
    wonder if when the first nut was tightened down the spring hat didnt locate.
    I had a similar issue with me mk3 cup kit.
    Wonder if that then caused the dead bearing from not sitting flat?
    Jul 2010
    It looked flat as I dismantled. But the damage is definitely on one side which would support what you said.
    Could it not be over tightening?
    im trying to remember how the stock suspension looks when going together, its been a while.
    from memory that spring hat doesnt tighten down to anything? just slides over the shaft?
    Jul 2010
    Here
    What would cause this damage?-screen-shot-2016-08-06-6-52-47-pm-png
    The cap slides over the shaft, we don't use #7, then 6 (bearing) and 5 (strut top) are screwed onto the shaft, so if the nut (#4) is too tight, i'm wondering if the bearing would be the weakest link.
    Thanks Dylan.
