Currently Skyline, RX7, 300ZX and more 5 bolt jap stuff. Centre bore should be 66mm to allow easy 4 x 100 conversion.
Hey guys,
BBS RS 16" X 7"
PCD: 5 x 114.3
Offset: +30
Can they be adapted to fit a current 4x100
Thanks rim nuts..![]()
Can you take pics of the underside? If the hub back is flat, you can have them filled and redrilled. 16x7 ET30 would be a pretty good fitment, fronts shouldn't rub with 195/45R16 tyres.
If it's not flat-backed, then the only way they'll go on is with adapters, but they will be too thick and will push the wheels out too far out.
Just a heads-up, filling + redrilling will cost around $400 - $550, and 195/45R16 tyres don't come cheaply either.
Nah The back ain't flat.So can't be re drilled. I just could of got em for WAY cheap thats all and didn't know what they'd fit. Oh well. i'll keep looking. Thanks for the input guys. Your knowledge sometimes blows me away...
Ive got some spare centres exactly the same as these if you want to practiseIve had the same wheels redrilled but Flat back, dont believe its possible other wise unless you stay with a 5 stud.
My 16x7et33 and 16x8et24 are kinda on the market $1800 with near new tyres. They just get older the more i drive it!
