MKIV 2004 2slow Sport
H&R Sport Springs.
Front 1.4" Lower Rear 1.5" Lower
Stock Shocks
Handles good, no body roll.
I can feel the bumps more.
Will upgrade shocks when they wear out, looking at Koni's.
H&R Sport Springs.
Stock Shocks
1998 Golf GL 2.slow
Eibach pro spring kit on standard shocks, 38mm drop all round.
Sits flat on the road i.e dual lane roundabouts at well over the speed limit and in the lines, and works well with my nice silverstone 205/45/16W tires.
I'm happy![]()
80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
h&r coilovers
h&r front and rear sway bars
uprated engine mounts and dogbone mount.
about to uprate suspension bushes.
sticks to the road like superglue!! and not bone jarring rough.
In car:
Koni Special (Red) shocks - front = half-turn from stiff, rears = 3/4 turn from stiff
Ground Control spring seat sleeves (height adjustment)
Ground Control/Eibach custom springs - front = 300 lb, rear = 250 lb
Have but not installed yet:
Front HD strut mounts
Rear polyurethane strut mounts
Eibach flat strut bar
VR6 control arms and ball joints
Cut springs!That hurts.
Just recently installed:
K-Sports fully adjustable Coilovers all round
Back dropped as low as it will go
Front to match
Up next: Rear sway bar
Awsome ride and the handling is mental!
(]/_ O _____ O _\[)
"'(O8o)=\X/=(o8O)
[__|========|__]
Polo GTI: Bilstein PSS9's - + 30lb of extra spring rate - rest is stock
Golf GTI MKV - Sach's racing 20 way adjustable coilovers - rest is standard
Audi TT - Ohlins motorsport suspension, 380 lb springs, custom camber plates (capable of 5 deg neg camber) - stock swaybars, H&R adjustable rear control arms.
Porsche Cayman S: Sach's Racing Coilovers, Mantis Sport Camber plates, 997 GT3 front bar, Tarret adjustable rear sway bar, tarret sway bar links.
All of them corner pretty well![]()
How much did that cost you and where did you get it from? Sounds like sorta suspension i need for my driving
I'm looking at getting some H&R race springs from the US.... i think it'll cost about $260 american though (2" drop at front, 1.75 rear)... and KYB shocks - not expensive.
Edit: after reading other forums, and i think eibach springs are over $500 a set.... I think i'ma go with KYB shocks and Whiteline springs. Sounds like they're about 40mm lower, and eliminate "floating" feeling when driving and body rollcan't wait...
