lowerd koni shocks
lowerd springs cut (i know i know its bad)
setup is only temporary ATM
other than that the ride is perfect like standard and handles really well
wabit
After the last post I thought it might be good to get an idea of just what everyone is running, coilovers, pollybuses etc
So though id start:
My plan
solid adj strut tops
polly bushes throughout
Koni or Kw coilovers
25mm front arb
28mm rear arb
Planing for track days, fast road etc....
ok I know this my plan a nd not my car at the mo, but its the sort of list im looking for!
lowerd koni shocks
wabit
My setup is:
-KW Front Anti-Sway bar.
-KW coilovers (V1's).
-Neuspeed adjustable rear anti-sway bar.
No complaints at all with this setup, the car is on rails and everyone who rides in the car comments on the surprising ride comfort.
Snowy![]()
kings springs - extra superlows (cut 1 or 2 coils)
Mines moderate I guess but it does the trick for me anyway:
-KW V2s
-New strut top mounts
-Neuspeed Front Strut brace
-Rear strut brace
Also looking at picking up a rear sway bar as whoever I have talked to I have heard that the rear sway bar is one of the best suspension/handling mods you can do.
My Mk5 GTI is stock as a rock at the minute. Still deciding which way to go.
My mk3 VR6 has
installed already
PSS9 coilovers (in dire need of a rebuild)
neuspeed rear swaybar
on their way over or waiting in my garage to be installed
WRD Lower stress bar
HD upper strut mounts
R32 control arm bushes
front eibach strut brace
Red MkI 5door 1979
Front
Kings springs 30mm lowered springs
Gabriel Gas Ryder strut inserts.
GTI sway bar
SuperPro poly control arm bushes to be fitted.
Std GLS solid discs and callipers.
MKII GTI Steel wheels 14x6.
195/60/14 Bridgestone G'grids
Rear
Gabriel Gas Ryder Struts.
GTI sway bar
Superpro poly Beam Axle Pivot Bushings to be fitted
'97 Cordoba drum brakes.
Cordoba Booster and 20.6mm master cylinder.
White MkI 5door 1979
Front
Upper strut brace.
Lower strut brace.
Whiteline 24mm sway bar
Std GTI vented discs and callipers.
185/60/14 B.F.Goodrich g-force sports
Rear
Upper strut brace.
GTI sway bar
Toledo solid discs and callipers.
MK III booster and 22mm master cylinder to be fitted.
KW V2 Coilovers
20mm front & rear sway bars (nfi on brand)
stock bushings
Fairy basic but I'm happy with the handling. Just wish I had some decent tires, nexen 3000's suck!!
Stock shocks
stock springs, chopped by 4"'
