Results 1 to 10 of 18
Thread: What is everyones suspension setups?
    Jul 2007
    Earlwood Sydney
    After the last post I thought it might be good to get an idea of just what everyone is running, coilovers, pollybuses etc
    So though id start:
    My plan
    solid adj strut tops
    polly bushes throughout
    Koni or Kw coilovers
    25mm front arb
    28mm rear arb
    Planing for track days, fast road etc....
    ok I know this my plan a nd not my car at the mo, but its the sort of list im looking for!
    Nov 2005
    lowerd koni shocks
    lowerd springs cut (i know i know its bad)
    setup is only temporary ATM
    other than that the ride is perfect like standard and handles really well
    wabit
    Canberra
    My setup is:
    -KW Front Anti-Sway bar.
    -KW coilovers (V1's).
    -Neuspeed adjustable rear anti-sway bar.
    No complaints at all with this setup, the car is on rails and everyone who rides in the car comments on the surprising ride comfort.
    Snowy
    Aug 2006
    kings springs - extra superlows (cut 1 or 2 coils)
    Sep 2006
    Australia?
    Mines moderate I guess but it does the trick for me anyway:
    -KW V2s
    -New strut top mounts
    -Neuspeed Front Strut brace
    -Rear strut brace
    Also looking at picking up a rear sway bar as whoever I have talked to I have heard that the rear sway bar is one of the best suspension/handling mods you can do.
    Point Cook, Vic
    My Mk5 GTI is stock as a rock at the minute. Still deciding which way to go.
    My mk3 VR6 has
    installed already
    PSS9 coilovers (in dire need of a rebuild)
    neuspeed rear swaybar
    on their way over or waiting in my garage to be installed
    WRD Lower stress bar
    HD upper strut mounts
    R32 control arm bushes
    front eibach strut brace
    my sportline is running...
    FK Koni Sport coilovers
    Front upper and lower strut brace
    Rear strut brace
    poly bushs and swaybars to follow
    Ps, the pic below is my old koni shock and springs!!!!
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Boronia VIC
    Red MkI 5door 1979
    Front
    Kings springs 30mm lowered springs
    Gabriel Gas Ryder strut inserts.
    GTI sway bar
    SuperPro poly control arm bushes to be fitted.
    Std GLS solid discs and callipers.
    MKII GTI Steel wheels 14x6.
    195/60/14 Bridgestone G'grids
    Rear
    Gabriel Gas Ryder Struts.
    GTI sway bar
    Superpro poly Beam Axle Pivot Bushings to be fitted
    '97 Cordoba drum brakes.
    Cordoba Booster and 20.6mm master cylinder.
    White MkI 5door 1979
    Front
    Upper strut brace.
    Lower strut brace.
    Whiteline 24mm sway bar
    Std GTI vented discs and callipers.
    185/60/14 B.F.Goodrich g-force sports
    Rear
    Upper strut brace.
    GTI sway bar
    Toledo solid discs and callipers.
    MK III booster and 22mm master cylinder to be fitted.
    Feb 2007
    Perth, WA
    KW V2 Coilovers
    20mm front & rear sway bars (nfi on brand)
    stock bushings
    Fairy basic but I'm happy with the handling. Just wish I had some decent tires, nexen 3000's suck!!
    Apr 2006
    Stock shocks
    stock springs, chopped by 4"'
