Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: What is everyones suspension setups?
    -KW V2s
    -New strut top mounts
    -Whiteline Front and Rear adjustable sway bars
    -ECS tuning dogbone mount (black poly)
    -ECS tuning bushings all around
    Sticks like $%!T to a babys bum!
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Melbourne, Nth West
    MKIV 2004 2slow Sport
    H&R Sport Springs.
    Front 1.4" Lower Rear 1.5" Lower
    Stock Shocks
    Handles good, no body roll.
    I can feel the bumps more.
    Will upgrade shocks when they wear out, looking at Koni's.
    Jan 2007
    1998 Golf GL 2.slow
    Eibach pro spring kit on standard shocks, 38mm drop all round.
    Sits flat on the road i.e dual lane roundabouts at well over the speed limit and in the lines, and works well with my nice silverstone 205/45/16W tires.
    I'm happy
    gpk_gti Guest
    h&r coilovers
    h&r front and rear sway bars
    uprated engine mounts and dogbone mount.
    about to uprate suspension bushes.
    sticks to the road like superglue!! and not bone jarring rough.
    Sep 2006
    West Sydney
    In car:
    Koni Special (Red) shocks - front = half-turn from stiff, rears = 3/4 turn from stiff
    Ground Control spring seat sleeves (height adjustment)
    Ground Control/Eibach custom springs - front = 300 lb, rear = 250 lb
    Have but not installed yet:
    Front HD strut mounts
    Rear polyurethane strut mounts
    Eibach flat strut bar
    VR6 control arms and ball joints
    Sep 2007
    Syd, Northern Beaches
    Cut springs! That hurts.
    Just recently installed:
    K-Sports fully adjustable Coilovers all round
    Back dropped as low as it will go
    Front to match
    Up next: Rear sway bar
    Awsome ride and the handling is mental!
    (]/_ O _____ O _\[)
    "'(O8o)=\X/=(o8O)
    [__|========|__]
    Polo GTI: Bilstein PSS9's - + 30lb of extra spring rate - rest is stock
    Golf GTI MKV - Sach's racing 20 way adjustable coilovers - rest is standard
    Audi TT - Ohlins motorsport suspension, 380 lb springs, custom camber plates (capable of 5 deg neg camber) - stock swaybars, H&R adjustable rear control arms.
    Porsche Cayman S: Sach's Racing Coilovers, Mantis Sport Camber plates, 997 GT3 front bar, Tarret adjustable rear sway bar, tarret sway bar links.
    All of them corner pretty well
    Jan 2008
    Quote Originally Posted by Golf Houso View Post
    1998 Golf GL 2.slow
    I'm happy
    How much did that cost you and where did you get it from? Sounds like sorta suspension i need for my driving
    I'm looking at getting some H&R race springs from the US.... i think it'll cost about $260 american though (2" drop at front, 1.75 rear)... and KYB shocks - not expensive.
    Edit: after reading other forums, and i think eibach springs are over $500 a set.... I think i'ma go with KYB shocks and Whiteline springs. Sounds like they're about 40mm lower, and eliminate "floating" feeling when driving and body roll can't wait...
