Results 1 to 2 of 2
Thread: VW Bora Lowering Caps
    Jan 2013
    Queensland
    Hey All
    Recently I've installed some SPAX lowering springs that have given me approximately a 30mm drop all round. It isnt exactly what I was hoping and I've got the itch to drop it a bit lower.
    Rather than going coilovers (as I have good quality Bilstein shocks in there) whats everyones thoughts/experiences with lowering caps?
    From what I gather you can just remove the old hat on the front strut and replace it with this thinner cup?
    Heres and example of one.
    VW Golf Jetta MK4 10 12mm Front lowering Discs Caps | eBay
    A 10-15mm drop on the front would be all im after... Thanks in advance!
    Sep 2006
    West Sydney
    I've never tried those as I usually go straight for coilovers (which uses its own top spring cap) but I have replaced my standard front strut mounts for Polo 6N ones instead, and they provided a decent drop too. It just replaces your current rubber mount, but it uses the same bearing. I've used it with good results; no knocking, no problems. I've removed it after a few thousand kms too, and it still looks fine, with the bearing still working as it should.
    All the info you need here - Shorter Top Mounts - The Mk4 - Edition 38 Forums
