Hey Stephy,
No idea on what coilovers you are running, but a rear swaybar should help. Are your coilovers adjustable? This might be an easy fix. How old is the VR6? It may be time to upgrade the bushes which will aid the whole suspension.
How many kms on the coilovers? They could be nearning the end of their life.
I don't know much about the VR6's sorry, but I assume it already has a soft front swaybar. A strut brace helps handling, I don't think it would change the bodyroll much.
A rear sway is easy to install, a front sway often requires dropping the subframe or other fun stuff, so is less of a DIY and better to do with other parts.
