It'll work short term but the extreme pressure on the wheel seat will deform it (3000 series aluminum is much softer than steel), creating clearance => loosening off over time.
So unless it's an emergency, it would be silly not to buy the correct bolts or nuts.
Plus it buggers the seat for when you use the proper fasteners.
Resident grumpy old fart
