Compared to the 205/55R16, 225/45R17 has a 0.41% larger rolling circumference while 215/45R17 is 1.05% smaller so neither is a huge difference. Note that the larger rolling circumference of your current tyres will reduce odometer readings by the 0.41% and therefore reduce the mileage calculations by that degree, so your car thinks it is using even more fuel than what is caused by the extra drag (both rolling and air).
Here is my favorite site for checking this as it allows multiple sizes to be compared: Tire Size Calculator - tire & wheel plus sizing
Just to explain the effect on the load rating - air volume provides the primary support for a vehicle's weight and with all other things being equal, when tyres are of the same width and rolling circumference, the one with the larger rim size will have a lower load rating as the enclosed air volume is smaller. Manufacturers can strengthen a tyre's sidewalls to a degree to create the extra load version but due to the extra material required, you get the downsides as mentioned by Diesel_vert.
Resident grumpy old fart
