Results 1 to 10 of 15
Thread: Tyre wearing out on the edge
    Jan 2010
    Is it a known problem with the rear tyres wearing out on the inner wall.
    Aug 2012
    Was for my old Saab. Kinda depends on the camber & castor. Best to get your alignment done.
    Difinity
    What model car?
    Had an alignment recently?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jan 2010
    It's mk6 gti
    Front camber was fine,
    The rear was not wearing out evenly.
    should they have neutral camber on the rear?
    got a picture of the tyre, is it camber or toe wear?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jan 2010
    sorry
    what is the difference between camber and toe wear?
    toe wear will normally 'tear' or feather at the tyre tread.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jan 2011
    Brisbane - QLD
    factory alignment for the mk6 gti sets rear wheels at 1 degree 45 minutes camber or 1.75 degrees, with tolerance +- 30 minutes or 0.5 degree camber.
    if you don't rotate (or too lazy do DIY) your wheels at least once every 10,000km of course you will get uneven wear on the 4 tyres.
    depending on how many k's you have done, if less than 25,000km then your alignment must be out!
    MINI Cooper S Clubman - FWD
    Jan 2010
    Looks more like toe wear to me. Might swap the tyres around.
