Was for my old Saab. Kinda depends on the camber & castor. Best to get your alignment done.
Difinity
Is it a known problem with the rear tyres wearing out on the inner wall.
Difinity
What model car?
Had an alignment recently?
It's mk6 gti
Front camber was fine,
The rear was not wearing out evenly.
should they have neutral camber on the rear?
got a picture of the tyre, is it camber or toe wear?
sorry
what is the difference between camber and toe wear?
toe wear will normally 'tear' or feather at the tyre tread.
Tire Wear Patterns: What Do They Mean?
this might help
factory alignment for the mk6 gti sets rear wheels at 1 degree 45 minutes camber or 1.75 degrees, with tolerance +- 30 minutes or 0.5 degree camber.
if you don't rotate (or too lazy do DIY) your wheels at least once every 10,000km of course you will get uneven wear on the 4 tyres.
depending on how many k's you have done, if less than 25,000km then your alignment must be out!
MINI Cooper S Clubman - FWD
