Results 1 to 7 of 7
Thread: Tyre suggestions
    Aug 2012
    Sunshine Coast, QLD
    Tyre suggestions
    Hey Guys,
    new wheels have arrived -
    So, they are 8.5" wide 19's looking to see what your tyre suggestions are.
    Thinking a 235/35 Nitto NT05 or Nitto INVO's or some Toyo R888
    As I only drive the car on weekends tyre wear really isnt an issue - I just want performance and looks to match.
    I dont mind a little stretch but do not want to much, has anyone got any of the above tyres on the same size wheel? have looked around for some pictures but not an easy one to find!
    Jul 2011
    Toyo R888's: Reasonable price for an R Spec tyre for track use. Be careful in the wet. Noisy and a hard ride for the street.
    Dec 2012
    Sutherland Shire, Sydney
    The Nitto's are not what I would call performance tyres
    A set of Goodyear Asymmetric F1 would provide great absolute performance and are well priced
    The Toyo R888 (being semi slick) work well simply due to the amount of rubber in contact with the road
    dont expect any stretch at all with a 235/35 on a 8.5
    every second mk5 on here using 19s run that size so id be check around the mk5 section for some hints
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Erskineville, NSW
    Quote Originally Posted by Martin View Post
    NT05 isn't a bad thing
    Dec 2012
    Yeah, like the R888 it would have a more than average amount of rubber in contact with the road
    I have a pair of NT01 semi slicks - they've been a bit disappointing
    They are very sensitive to heat and pressure
    Even when you get them happy they are just avaerage (for a semi slick - but better than using road tyres on the track)
    Aug 2012
    Sunshine Coast, QLD
    Thanks for your input everyone!
