where did you measure the width from? Remember it's the inside of the beads not the further most edges of the wheels.
IF it is an 8" wide wheel, a 195/50 does give a bit of stretch. (consideration must also go to ride height etc etc)
If it's a 7" (I suspect it might be) a 185/45 will look good, it'll be a nice 'straight' edge. But you'd need a 165/50 for a really stretched look.
You could also go a 185/45 on an 8" rim, although that is a fair amount of stretch and will defiantly get you a bit more attention (police wise) as it's defiantly undersized for the rim.
Hope this helps.
Oh, and www.tyrestretch.com
