2011 T5 132kw 7spdDSG 4motion, '89 Citroen 2CV, 2006 Subaru Forester SG 5spd
Found this nice tool for calculating all the possible tyre sizes that match a specified size: Tire Size Calculator
Output gives you something like this:
Tyre Size Diameter Circumference Difference Speedo Fits Wheel Rim
205/80 R14 684mm / 26.93" 2149mm / 84.61" -0.88 % 59.47 5.5x14 to 7x14
225/70 R15 696mm / 27.40" 2187mm / 86.10" 0.88 % 60.53 6x15 to 7.5x15
205/75 R15 688mm / 27.09" 2161mm / 85.08" -0.32 % 59.81 5.5x15 to 7x15
195/80 R15 694mm / 27.32" 2180mm / 85.83" 0.55 % 60.33 5.5x15 to 7x15
255/55 R16 686mm / 27.01" 2155mm / 84.84" -0.60 % 59.64 7x16 to 8.5x16
235/60 R16 688mm / 27.09" 2161mm / 85.08" -0.32 % 59.81 6.5x16 to 8x16
215/65 R16 686mm / 27.01" 2155mm / 84.84" -0.60 % 59.64 6x16 to 7.5x16
185/75 R16 684mm / 26.93" 2149mm / 84.61" -0.88 % 59.47 5x16 to 6.5x16
175/80 R16 686mm / 27.01" 2155mm / 84.84" -0.60 % 59.64 5x16 to 6.5x16
255/50 R17 686mm / 27.01" 2155mm / 84.84" -0.60 % 59.64 7x17 to 8.5x17
235/55 R17 690mm / 27.17" 2168mm / 85.35" 0.00 % 60.00 6.5x17 to 8x17
215/60 R17 690mm / 27.17" 2168mm / 85.35" 0.00 % 60.00 6x17 to 7.5x17
285/40 R18 686mm / 27.01" 2155mm / 84.84" -0.60 % 59.64 9.5x18 to 11x18
255/45 R18 686mm / 27.01" 2155mm / 84.84" -0.60 % 59.64 8.5x18 to 10x18
235/50 R18 692mm / 27.24" 2174mm / 85.59" 0.28 % 60.17 6.5x18 to 8x18
215/55 R18 694mm / 27.32" 2180mm / 85.83" 0.55 % 60.33 6x18 to 7.5x18
255/40 R19 686mm / 27.01" 2155mm / 84.84" -0.60 % 59.64 8.5x19 to 10x19
225/45 R19 686mm / 27.01" 2155mm / 84.84" -0.60 % 59.64 7.5x19 to 9x19
235/45 R19 694mm / 27.32" 2180mm / 85.83" 0.55 % 60.33 8x19 to 9.5x19
295/30 R20 686mm / 27.01" 2155mm / 84.84" -0.60 % 59.64 10x20 to 11.5x20
255/35 R20 686mm / 27.01" 2155mm / 84.84" -0.60 % 59.64 8.5x20 to 10x20
265/35 R20 694mm / 27.32" 2180mm / 85.83" 0.55 % 60.33 9x20 to 10.5x20
265/30 R21 692mm / 27.24" 2174mm / 85.59" 0.28 % 60.17 9x21 to 10.5x21
It also gives you the option to increase the %error to include more tyre sizes that are also close in rolling diameter.
Neat little tool.
