Results 1 to 6 of 6
Thread: Tyre Conumdrum
    syncro Guest
    Don't believe everything you hear from a tyre shop!
    These are the same retards that damage your car when jacking it up, lose your wheel nuts, tighten the wheel nuts to 300nm, forget to put the valves in and tell you that Australian made tyres are good.
    If it's for the passat then Nexen N2000's will be cheap/adequate!
    Mar 2006
    Canberra
    Thanks for the advice so far. I neglected to mention Iwould be getting a good price on both brands of $99 dollars per tyre, a saving between $20 and $30 per tyre.
    Old Skool Passat Power Rules!!!
    1974 Passat LS with a SEAT 1.8, 32/36 Weber, full performance exhaust and a K&N filter. 80kw at the wheels??
    Gosford Central Coast NSW
    big up firestone firehawk wide ovals, or continental premium contact!
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Mar 2006
    Canberra
    Talking
    Got the Falkens before Xmas went to Dubbo running 40psi on both front and rears and the performed fantasticly well. Just got back from a drive to Young again the were great. Haven't had much of a go in the wet as yet, so I will keep all posted. Sorry should have followed up earlier.
Similar Threads
  1. VR6 Fuel Economy / Tyre Pressure Quiz
    By gman in forum Mk3 Golf & Vento
    Last Post: 10-03-2007, 07:51 PM
  2. 18" wheel and tyre reccomendations for Jetta
    By LS1 Cobra in forum Mk5 Golf & Jetta
    Last Post: 14-07-2006, 12:39 PM
