no chance
18x8.5 et 48 is about flush. So you would be hanging out the front guards by over 10mm
hi guys,
Will these fit or will I need body work for it to work?
no chance
crap!
Can I not roll the guards?
It might be possible to make them fit but it depends on how committed to the cause you are. Body work is expensive. You would need more that just a light rolling to make them fit I reckon.
Id think its better to find something a little more conservative.
You can make them fit depending on what tyres you run and how low you go. This fitment guide is perfect and tells you what rims sizes and what tyre sizes can potentially work.
MkV wheel/tire fitment guide - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com
The other option would be to mill the inside down 5-7mm. That would work wouldn't it?
Oh, They're ET32 not 35!
it depends on the design of the wheel on whether you can shave some off the mounting face. Usually you can get away with a couple of mm but nowhere near what you need.
Without modification even if you did make them fit they would look ridiculous with that much poke unless you were stupidly low, willing to have massively stretched tyres and rub everywhere you go.. That spec is probly more suited to a passat or A4
Crap crap crap crap crap!!!!!
Damn cheap wheels too!
