Results 1 to 9 of 9
Thread: Tried search No Luck- 18x8.5 et35 on a MK6 Golf
    Feb 2009
    NSW
    hi guys,
    Will these fit or will I need body work for it to work?
    Point Cook, Vic
    no chance
    18x8.5 et 48 is about flush. So you would be hanging out the front guards by over 10mm
    FOLLOW US ON FACEBOOK
    Feb 2009
    NSW
    crap!
    Can I not roll the guards?
    Point Cook, Vic
    It might be possible to make them fit but it depends on how committed to the cause you are. Body work is expensive. You would need more that just a light rolling to make them fit I reckon.
    Id think its better to find something a little more conservative.
    Oct 2006
    You can make them fit depending on what tyres you run and how low you go. This fitment guide is perfect and tells you what rims sizes and what tyre sizes can potentially work.
    MkV wheel/tire fitment guide - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com
    Feb 2009
    NSW
    The other option would be to mill the inside down 5-7mm. That would work wouldn't it?
    Feb 2009
    NSW
    Oh, They're ET32 not 35!
    Point Cook, Vic
    it depends on the design of the wheel on whether you can shave some off the mounting face. Usually you can get away with a couple of mm but nowhere near what you need.
    Without modification even if you did make them fit they would look ridiculous with that much poke unless you were stupidly low, willing to have massively stretched tyres and rub everywhere you go.. That spec is probly more suited to a passat or A4
    Feb 2009
    NSW
    Crap crap crap crap crap!!!!!
    Damn cheap wheels too!
