Page 7 of 20 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 197
Thread: Tirerack experiences?
  1. #61
    Erskineville, NSW
    Quote Originally Posted by Diesel_vert View Post
    Both 225/55 R16 and 225/50 R16 tyres can be fitted on 6.0" - 8.0" wheels.
    Thanks
    That'll learn me to just pull stuff out my khyber
  2. #62
    May 2011
    QLD
    According to
    Tyre Calculator - Alloy Wheels - Specialist supplier of alloy wheels and tyres packages, Fast Delivery, Buy Online.
    The recommended width of rims for 225 wide tires are up to 7.5"
    One thing I have noticed is that it seems easier to kerb rims when the tires are on the narrow side of the allowed range.
  3. #63
    Jan 2009
    Quote Originally Posted by DoggieHowser View Post
    According to
    Firstly, that website is just plain incorrect (ask any tyre manufacturer).
    Secondly, it is also incorrect to state that "225 wide tyres are limited to 7.5" wheels" - you also need to specify the profile. For example, a 225/35 tyre can be fitted on 7.5" to 9.0" wheels.
  4. #64
    Erskineville, NSW
    What diesel vert said.
    You'd have to be a shocker of a parker to kerb 225/55x16 on 7.5" rims. Lord knows I've tried. The dam things are like ATV tyres.
  5. #65
    the rules of what can and cant fit on what width wheel also depends on each tyre...
    really need to check with each manufacture and each model. iv put 225/40s legally on a 9 before, the next tyre may only go to a 8 or 8.5 due to its structure. tyre rack is good for looking as this as they list all the info in one place, saves ringing various places and getting told the wrong thing.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  6. #66
    Jan 2009
    Any 225/40 tyre can be fitted on 7.5" to 9.0" wheels without problem, notwithstanding any clearance issues in regards to the car.
    But whether a tyre can be physically seated on a wheel beyond the approved fitments is of course dependent of the tyre itself (which is what I think you're getting at).
  7. #67
    nar just mean some tyres (like slicks for an extreme example) tend to have a narrower range of widths they can legally be fitted too (cant go too skinny or wide).
    as in each brand/model/version is different too the next, so there isnt a rule of "a 205/55/16 will fit xx" - xx" range wheel", each tyre needs to be checked
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  8. #68
    Jan 2009
    Well, racing tyres are a whole different ballgame so I won't go there.
    Tyre dimensions have been broadly standardised by the various tyre and rim associations in each region: ETRTO (Europe), TRA (U.S.), JATMA (Japan), TRAA (Australia) and others.
    I would expect something as fundamental as tyre dimensions and allowable wheel fitments regarding passenger car tyres to be mostly uniform.
    Whether a tyre can be physically seated on a wheel, beyond those listed in their standards manual, is down to trial and error.
  9. #69
    Erskineville, NSW
    Dylan8 is right. 99% of tyres will have the same recomended rim ranges but every now & then you'll get an odd-bod that is half an inch either way.
    This is because some manufacturers cheat in how they make a tyre (usually a low demand size). eg (plucks sizes out of air): to make a low demand 245/40x17 they might use the case of a 235/40x17 case & build it in such a way that the dimensions just slip into the size range allowable for a 245/40x17. I've seen the same "size" tyre from different manufacturers vary in both width & diameter by a visually noticeable amount (up to 25mm) & that's disregarding the optical illusion you get when the shoulder blocks are rounded rather than squared off.
    It was also obvious when fitting the tyre. Some brands the bead would self seal with a quick blast through the valve; others needed a lubed-up rubber spacer inserted to take up the gap or an air blast ring
    Very rare but it did happen.
  10. #70
    Mar 2009
    Brisvegas
    Quote Originally Posted by walbjj View Post
    Yowie, why do u say that as if u doubt it. Tirerack has been used by many Australians and the overall majority have said its half price with a week shipping.
    I'm buying again, Goodyear assymetric 2 in 18", $1200 delivered, that's the cost of 2 tyres here
    Hey Deisel_vert , I dont doubt the great shelf prices.
    I was merely reflecting that I, as a digital immigrant, am going in totally blind, buying based on what I have read here trusting that Tire Rack will perform in terms of delivery and service. Thansk for the advice on rim sizes, TDI Pacific i thought runs 7's, I dont have it here at the moment. Hopefully the 225/50's are going straight on and not adding to any gutter rash risk, good point!
    I will let you know how it runs.
    MY09 Golf Candy White 2.0 TDI Pacific
    MY95 Golf III TDI
