Results 1 to 10 of 11
Thread: Tire split at the seams - 2017 Skoda Superb 206
    Aug 2008
    NSW
    Tire split at the seams - 2017 Skoda Superb 206-img_0540-jpg
    I was at the local shops (1km away) and on the drive home the tire pressure gauge came on, within 200 metres from home it felt like a puncture, I nursed it home and discovered this.
    It seems the tyre has disintegrated at the seam. Only 13000 kms on the clock, the car was serviced 1 month ago and Skoda advised the tires where fine.
    Is this odd? Is it likely wear and tear or a tire defect?
    Should I take it to Skoda?
    Dec 2008
    Sydney/Canberra
    Take it to the manufacturer of the tyre.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    May 2007
    Where they Pirelli?
    Yes, take it up with both Skoda and the tyre manufacturer (whom ever that is)!
    Apr 2018
    Quote Originally Posted by mattyf83 View Post
    It looks like it may have copped a hit, pothole or gutter ?
    Passat Alltrack Wolfsburg Edition My18
    Jul 2010
    Robina Gold Coast
    Looking at the rim ,Looks like it has hit the kerb as paint has been removed
    You could try but i doubt your chances of getting it replaced ,
    Aug 2008
    NSW
    There is a superficial scratch to the rim which has been there for a while. This was from scraping a curb whilst parking.
    Hardly going to a cause an entire tyre to split
    Looks like the tyre was so flat that you’ve damaged the sidewall.
    You can see that there’s a circle all the way around where the sidewall has collapsed and has been folded over and driven on.
    I’d say you’re up for a new tyre. I’d also check there’s no damage to the rim too.
    Feb 2015
    Sydney, Australia.
    tape it up she'll be fine
    Jul 2007
    Brissy
    Tyre shop will probably say they cannot patch it as it is too close to the sidewall
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Mar 2017
    Tasmania
    Driving a couple of hundred metres on a flat tyre will do that. The tyre didn’t split - you driving on it cut it open.
