Results 1 to 10 of 17
Thread: Tire pressure
    Apr 2006
    Melbourne, Victoria
    Tire pressure
    Hello all,
    I was just told that im going to die in a fatal car crash if i continue to run my tires at 35psi.
    So, to be sure, whats the advantage/disadvantage of using higher tire pressure?
    What pressure do you recommend?
    (Mk1 13x5.5 steelies and Mk1 14x6 alloys)
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    Jun 2007
    Eastern Suburbs Melbourne
    I ran 35psi up and back to sydney on stockies.
    i do believe i'm not dead, nor did i die in a fatal car crash.
    i like volkswagens
    Quote Originally Posted by hiho View Post
    Hello all,
    Who told you that?
    i have 18s with 40 profile, i was told to run them at 32psi for a 'soft' ride, and 35psi for a harder ride but longer lasting tyre, mine are currently inbetween..
    Dont know of the advantages/disadvantages other then that sorry
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    May 2009
    Western Sydney, NSW
    Blog Entries
    1
    The recommended pressures should be in your manual, but for the Tiguan I believe it's 36PSI or something close to that. Your tyres at that pressure shouldn't be so hard so as to reduce your traction levels, so tell whoever told you that to wipe their chin coz they're talking sh*t.
    Tiguan TDI, 6spd Tiptronic Auto
    Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
    Avg 7.63L/100km over 189,000kms
    Mar 2008
    I think my 205/40/17 are at 38 front and 36 rear, or 40/38, can't remember.
    Jun 2008
    Ringwood, Victoria
    My Mk4 golf with 15" alloys says that the tires should be run at 41psi as stated on the fuel filler cap. Depending on the height of your sidewalls, I think 35psi is a pretty normal pressure. I used to run all-terrains on my 4x4 at 44psi for everyday driving and I ain't dead...
    brisbane qld
    Hello all,
    Completely untrueand without substance. Your source is wrong and stupid.
    HTH
    Jul 2005
    Newcastle, NSW
    There are a few things that need to be considered with tyre pressure, like load over the axle, the sidewall of the tyres, the compound of the tyres, the camber and caster settings of the alignment etc etc.
    I just put 195/50R15 on the MK1 and run them at 28psi, this is a conclusion I have reached after having some inaffective braking in the wet at 32 rear 34 front and some really upsetting ride sensations at 30 front an rear.
    Some will say that you must always use XYZ, but the best guide for ride and handling (not sports handling) is the manufacturers specification (for a MK1 I am unsure of).
    I also suggest you play with your settings to find what suits both your car and style of driving.
    Jul 2005
    Newcastle, NSW
    Quote Originally Posted by vw poster View Post
    HTH
    It is unsubstanitated, however is is plausable that we may have hiho in a fatal car accident while his tyres are at 35psi.
    The source is providing misleading information rather than wrong, but I am unsure if he is stupid or just not communicating his point very well.
    brisbane qld
    Quote Originally Posted by mikinoz View Post
    Tyre pressure of 35 psi will not be the cause of of a fatal accident on its own.Type, condition, speed and weather are all factors.
    Manufactures always recommend a lower pressure to ensure comfort and reduced tyre roar. Any reputable tyre specialist will recommend a few PSI above the manufactures numbers. There is a wealth of tyre pressure information from Tyre manufactures that confirms this.
    Some sensible debate rather than childish speculation is in order.
