I have also found the FK AK Supertech coilovers.
They are listed as the entry level of coilovers for the budget conscious driver. These can be found for as little as ~AU$503 + shipping frin venom or a little more from this mob: http://www.speedbox.co.uk/products/p...dget_coilovers
They are listed as Front and Rear 55-85mm.
It seems to move up to something with dampening adjustment moves the price to round the AU$1,000 or so mark. Mind you the lowering range also increases.
The one negative comment I have found so far on the FK AK "budget" line of shocks is that they can be fairly bouncy and with no dampening adjustment they guy said it was annoying. Still, only one bad comment, and even then I think I would be leaning towards the Supersports anyway
The other thing I have noticed on the FK's is that they say you *may* need wheel spacers if running stock wheels. Not 100% how that would effect the wheels I am running... No info is listed on needing spacers with the Supersports. Still digging anyway...
Question on the drop/adjustment listings? Does this mean it drops the car by a MINIMUM of 55mm and can be adjust to a MAXIMUM of 85mm? Or can you wind them all the way up something like the stock level?
