Very nice mate, watching with great interest, planning lower arms myself. RTR have the adjustable ball joint ends for these if you want more camber.
Installed these on the weekend:
ready to install:
weight comparison:
stock arms and bushings
and the outer part:
superpro arm and bushings
and the outer part
getting an alignment tomorrow, but on the short test drive I did, noticed much smaller steering wheel 'dead zone' and notably better grip over bumps/undulations.
Tyre life ought to be better out of sight
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
I have had these installed on my car for about two months or so now. They improve the car traction a lot. When I occassionally give it some boot, the traction control lights start flashing, but it has not broken traction. Once I got a tyre chirp, but loving this mod, it was worth it.
My main motivation is I do plenty of km on concrete freeway and tyre life could be better... with the 1.9TDI traction is not really a problem most of the time
Also, for anyone interested, I kind of expected the kit to come with grease but there was none. Anyway, I used red Castrol ...MRB?...i think... rubber grease (which I have been using on suspension bushings for years). You can buy a tub for around $10.
I also think that from time to time the rear bushing may need re-greasing. We shall see.
**EDIT**
Got a wheel alignment done, to fix the toe, good as gold and plenty of turn in...
Not sure about people saying how this mod improves 'traction' - certainly theres more corner grip now but it just makes the car so much more fun to thrash through corners, hence making the TCS light a whole lot more prevalent on my dash.
Before this mod, I didnt really like to push the car through corners as much.... now, its amazing.
Highly recommend.
'99 A4 Quattro 1.8T
Im def getting closer to pulling the pin on a set of these.
Volvo S60 RD T6
I know why you struggle with traction, just quietly.....
Call Greg at GSL he can get these, we were checking them out the other day.
Look the goods
Jmac
Alba European
