Originally Posted by
sambb
By the look of it your front cambers are spot on and your castors are very close too. The subframes are what your front wishbones are bolted to and if they are that close, you really wouldn't bother moving them for that. Yes your rear numbers are out a little. There is not really anything you can do about that. The camber and toe at the rear are all more or less set due to the fact that you have a rigid beam axle. I know that on my Polo the beam bolts into welded on receivers that can't be moved. Your mk4 may be different. All that can be done is the use of shims that fit under the stub axles to bring the cambers and toes into line with each other. To be honest though I've seen way worse on rear beams. For a car that age that's been smacking potholes and reversing up gutters etc its not too drastically out. But believe me I do get it - it sucks when the numbers say its not all fluffy and sux to see in the data like that. You'd be surprised but I bet that if you went tommorow to a different place you'd get a different set of numbers too.
