Does anyone have any voodoo incantations or magic that can help take off stuck fast wheel bolts? I honestly cannot get of the bolts off the front wheels, which need the tires to be replaced. Whoever torqued the bolts on last thought it would be a good idea to put them on tight enough so that there was never going to be a change to take them off...
Oh and did I mention the car is an unregistered VR6?
Thanks in advance, Branko.
80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
I remember that .... I really don't want it to come to that, although its looking like it.
They're on so tightly that I'm turning the wheel as I'm trying to undo the bolt. I also released my inner Balkan, that didn't help either and now there's a few more scratches on the rim
do up the other lugs nice and tight and try. otherwise go buy a nice big high tensile drill bit.
87' MK2 GTI
13' MK7 TDI
What have you been using to undo your lug nuts? See if you can loosen them by extending the handle with a pole. I haven't come across a nut/bolt I couldn't loosen when I've got like a metre long handle to untorque with.
I've got something here at home for you to use, let me know if you need it. You've got my number?
U just need a longer breaker bar and someone to hold the brake pedal while u undo it. If its hard to undo thats fine, if its rounded thats a whole lotta problem there!
