Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Stuck wheel bolts :(
  1. #21
    Jan 2007
    Quote Originally Posted by rayray086 View Post
    Glad it worked out Branko. VR6 lugs are M14x1.5 if you're going out to a shop to buy new lugs. Better yet, replace those rounded nuts with locking nuts
    I'll definately look into getting some replacement bolts soon.
    Whats this chalky yellow stuff? Had the bolt seized or something?
    And this is why you should use a breaker bar
  2. #22
    I replaced one of mine lugs from Denlo parra for $7.
  3. #23
    Sep 2006
    West Sydney
    Could be thread-locker, which might explain why it was so hard to loosen the wheel lugs.
  4. #24
    Sep 2007
    yer. it's loctite
    87' MK2 GTI
    13' MK7 TDI
  5. #25
    Oct 2006
    its not loctite its just a build up of material/crud. if u think about it not all of the wheel bolt is wound into the hub, only the last 10-15mm and the rest is just sitting in the wheel hole where blieve it or not stuff collects. nobody in their right mind would put loctite on wheel bolts its stupid! someone has just overtorqued the wheel bolts, glad u got em off tho.
    ps: ebay the wheel bolts if ur not in a hurry!
  6. #26
    Jan 2007
    Quote Originally Posted by peedman View Post
    Oh I just got 2 from the stealer for $12 ... I almost couldn't take those two off they were that rounded, short term solution. I now have 2 new rims and front tires, 15x6 steelies from a MKIV, I'm still looking around for another 2 for the rear and some new *cough*nankangs*cough* as the front tires.
    Since the head of the bolt stick out on the steelies I'm definately going to look for some nice new bolts on ebay...
  7. #27
    Sep 2006
    West Sydney
    Good point!
  8. #28
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by Golf Houso View Post
    Geeze, you could get some nice dress bolts instead for that sort of money
  9. #29
    Jan 2007
    Quote Originally Posted by The_Hawk View Post
    Been there done that, those bolts look good for a while the start the rust in the centres not fun
    Plus my VR is pretty ugly atm, like fancy bolts are going to make much of a difference in the short term, although I would like some nice black lugs once I get all 4 steelies on
