Results 1 to 10 of 15
Thread: Stock struts vs gti struts
    Jul 2011
    NEWCASTLE NSW
    I currently have eibach sportlines fitted with standard tdi struts. I'm
    More than happy with the ride quality, very little scrubbing, not too harsh etc. The front height is perfect but I wouldn't mind the rear being a little lower. I'm just wondering if fitting gti struts which are 15mm lower to the rear would bring the rear down at all ? Or is ride height mainly based on springs ?
    Scirocco R, APR 2+,VWR BBK,HP, QUAIFE, FORGE, VWR 18x9.
    Erskineville, NSW
    springs 1234
    Jul 2011
    NEWCASTLE NSW
    as cool as count dracula is, i dont get it
    Erskineville, NSW
    The Count! minimum character limit.
    Ride height is based on springs. Brand new gas struts might lift it a bit but will settle in time.
    You might look for a difference in the position of the spring mounts on the struts (tdi to gti).
    On the rear, the spring is mounted between the trailing arm & the body isn't it? The damper is seperate? Sometimes you can remove part of the rubber in the mount to get some drop but with a trade-off in NVH.
    Jul 2011
    NEWCASTLE NSW
    look like im stuck with a 5mm gap between guard and tire
    thanks for your help
    Oct 2010
    Melbourne, VIC
    If you're desperate to go low and broke, then you can always take an angle grinder to the springs...........
    Jul 2011
    NEWCASTLE NSW
    im not that desperate to go low, i mean theres only a 5mm gap between the guard the the tyre.
    Erskineville, NSW
    take that "no fat chicks" sticker off the back window - problem solved.
    Mar 2008
    Canning Vale, WA
    Hahahahahahahahahaha. Gold Jerry. GOLD.
    T Go
    MY11.5 Golf GTI | Bluefin Stage 2 | Pipercross Stage 2 Intake Pipe | AFE Pro 5R Filter | SPM Downpipe | VWR Sport Springs | H&R 22mm RSB | R LED Tail Lights
    Jul 2011
    Slacks Creek QLD
    Quote Originally Posted by kaanage View Post
    worst way you can do it would not recommend
    90 TSI 1.4T
