Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Stock struts vs gti struts
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by SMOK3Y View Post
    worst way you can do it would not recommend
    hence the "desperate"
    Jul 2011
    Slacks Creek QLD
    hence the smiley
    90 TSI 1.4T
    Oct 2010
    Melbourne, VIC
    Jokes aside, if racing on a budget, you can use this technique to work out what spring rate is needed if they're too soft (on a test day) provided you have adjustable damping and ride height.
    But for street lowering, yeah....
    Jul 2011
    Slacks Creek QLD
    ya the main problem i have with 'cutting' springs is they lose their actual 'spring rate' of the original spring. and most people seem to cut too much out lol
    90 TSI 1.4T
    Gosford Central Coast NSW
    As a basic explanation, spring rate of a coil spring works like this:
    directly propotional to:
    > elastic modulus of the steel used
    > wire diameter
    inversely proportonal to:
    > coil diameter
    > number of coils
    so, if you reduce the number of coils, the spring rate increases (spring gets harder).
    Another way to think of it is that if the spring had only 1 coil, you can imagine you would have a LOT of trouble compressing it (exactly analogous to trying to bend a very short bar). If you have a very long bar of the same diameter, you can bend it very easily.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
