alloys are softer than steel & can be heavier if going with larger dia.
Hey,
How are u all??
I wanted to get a set of steelies 15" or 16". To fit a set of semi slicks.
I only know steel is heavy substance, where as alloys is harder and lighter.
Other than that, what's the differences in performances? Please enlight the NOOB
Cheer,
Freddo-man
...BiG DuB...
\'95 Golf VR6
haha of course, larger the crap the heavier it is
well alloy with magnesium is softer than steel. But I dunnno about the performance nature of them.
Fred
...BiG DuB...
Check a periodic table, Fe is heavier than Mg
Steelies are great for track work IMHO
Soo steelies is good on the track..that's all i need hehe. Btw wat is IMHO???Steelies are great for track work IMHO
Thank You
Fred.
...BiG DuB...
true but your steelies are iron + other things which make it steel not ironFe is heavier than Mg
alloys aren't all magnesium either!
plus steel wheels are stronger than alloys - compare the thickness of steel used on the face of a wheel vs an alloy's spokes - the alloy iis much thicker (and rims for that matter)
alloys esp larger dia will have more weight at the circumference of the wheel = larger inertia = slower acceleration cos the car needs more power to get'em spinning
end of physics & materials class 101 (for the time being anyway)![]()
IMHO= in my honest opinion
\'95 Golf VR6
Alloy wheels are generally stronger than steel wheels.
Steel wheels are not recommended for track work as the centres are known to pull out.
Most wheels have a rating on them.
In my honest opinionOriginally Posted by vee_dub
Hey guys if you don't believe me call a wheel agent or a race car engineer or even ghost busters but steel wheels are a no no for the track ,alloy wheels would have a higher rating and even then some cheap and nasty import alloys aren't safe for the track either.
Its your neck and I don't post this info for nothing.
Originally Posted by Golfwise
Somebody kindly enlighten me.....I have tried to find out the load ratings supposedly stamped on alloys with no luck.
Ie. took the nos stamped on a number of Audi wheels to my local tyre expert and they meant nothing to him......got the same response from my local VW/Audi dealer..........should there be a kg or lbs stamp??
Trying to fit a set of either Audi/Mercedes alloys to my T4 doublecab that comply with the legal ratings.
Any thoughts......
