Results 1 to 10 of 17
Thread: Steelies v Alloys
    Nov 2005
    Steelies v Alloys
    Hey,
    How are u all??
    I wanted to get a set of steelies 15" or 16". To fit a set of semi slicks.
    I only know steel is heavy substance, where as alloys is harder and lighter.
    Other than that, what's the differences in performances? Please enlight the NOOB
    Cheer,
    Freddo-man
    ...BiG DuB...
    Oct 2005
    alloys are softer than steel & can be heavier if going with larger dia.
    \'95 Golf VR6
    Nov 2005
    haha of course, larger the crap the heavier it is
    well alloy with magnesium is softer than steel. But I dunnno about the performance nature of them.
    Fred
    ...BiG DuB...
    Jul 2005
    Newcastle, NSW
    Check a periodic table, Fe is heavier than Mg
    Steelies are great for track work IMHO
    Nov 2005
    Soo steelies is good on the track..that's all i need hehe. Btw wat is IMHO???
    Thank You
    Fred.
    ...BiG DuB...
    Oct 2005
    true but your steelies are iron + other things which make it steel not iron
    alloys aren't all magnesium either!
    plus steel wheels are stronger than alloys - compare the thickness of steel used on the face of a wheel vs an alloy's spokes - the alloy iis much thicker (and rims for that matter)
    alloys esp larger dia will have more weight at the circumference of the wheel = larger inertia = slower acceleration cos the car needs more power to get'em spinning
    end of physics & materials class 101 (for the time being anyway)
    IMHO= in my honest opinion
    \'95 Golf VR6
    Golfwise Guest
    Alloy wheels are generally stronger than steel wheels.
    Steel wheels are not recommended for track work as the centres are known to pull out.
    Most wheels have a rating on them.
    Oct 2005
    Nowra, NSW
    Quote Originally Posted by vee_dub
    Thank You
    Fred.
    In my honest opinion
    Golfwise Guest
    Hey guys if you don't believe me call a wheel agent or a race car engineer or even ghost busters but steel wheels are a no no for the track ,alloy wheels would have a higher rating and even then some cheap and nasty import alloys aren't safe for the track either.
    Its your neck and I don't post this info for nothing.
    GEELONG
    Quote Originally Posted by Golfwise
    Somebody kindly enlighten me.....I have tried to find out the load ratings supposedly stamped on alloys with no luck.
    Ie. took the nos stamped on a number of Audi wheels to my local tyre expert and they meant nothing to him......got the same response from my local VW/Audi dealer..........should there be a kg or lbs stamp??
    Trying to fit a set of either Audi/Mercedes alloys to my T4 doublecab that comply with the legal ratings.
    Any thoughts......
Similar Threads
  1. steelies!
    By KI11Z in forum Wheels & Suspension
    Last Post: 10-12-2006, 07:49 PM
  2. ALLOYS ON T4
    By DOUBLECAB in forum Wheels & Suspension
    Last Post: 19-01-2006, 02:23 PM
