Results 1 to 9 of 9
Thread: Splitting multi-piece BBS wheels
    Sep 2006
    West Sydney
    Are the bolts and nuts 12pt items? I know that the bolts are 8mm whereas the nuts are 10mm, but I'm just wondering what tools I need for it. Cheers.
    sydney
    yep multipoint sockets front n back
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
    Sep 2006
    West Sydney
    Thanks a lot. What about the sealant used? I've asked around in other forums and they seem to recommend Sikaflex. I can find their sealants at Bunnings and there's like a range of them too - any suggestions?
    Dec 2006
    Kilsyth, VIC
    Sikaflex is pretty expensive compared to others, but seems to be pretty good. I originally bought it to stick the locks back on quarter windows in a Mk1. Never use it for that. Doesn't work. Also don't get any on your clothes It's basically a very high end rubber cement.
    In my case, I got a tube to put in my corking gun. Tried it on the windows, failed. Put it away. 12 months later, I had to cut the tube in half to get anything out, I just couldn't unstick the nossel... Eitherway, it's now helping hold on my side trim and being that it has a fair give to it when set, it should do the job nicely.
    Next time round I think I will try for a small tube instead of the corking gun size jobbie, something with a lid I can put on and hopefully resuse later
    There is a whole range of Sikaflex stuff. Get a look here: http://www.sika.com.au
    Or just the automotive stuff here with a description of what each does: http://www.sika.com.au/cmi/auto_products_adh.htm
    Sep 2006
    West Sydney
    Yeah I heard they're the good stuff if you want it done well. There's just a whole range that I don't know what would be appropriate to use on wheels!
    Make sure that it's non-corrosive.
    http://www.dowcorning.com/content/et...al/default.asp
    The top one
    This is what we use on aircraft so it doesn't eat the aluminium skin, when sealing antennas on.
    Comes in a tube that would have plenty in to do a set of wheels.
    RS components would have it if you can't get it anywhere else.
    Sep 2006
    West Sydney
    Sounds good, cheers for that Gavin! No need to guess that they should be able to withstand the temperatures the wheels can get to, since you guys use it on aircraft!
    sydney
    there is a thread on vortex "bbs wide lip" or something of the sort it has all the info just search that and all your answers are answered
    rtv sealant basically saw some loctite heat proof rtv a few days ago thats what im gonna run
    Sep 2006
    West Sydney
    Quote Originally Posted by dubstarmk2 View Post
    http://forums.vwvortex.com/zerothread?id=1022742
    Is that the one? A lot of stuff in there I agree! I've also been checking out www.wheel-whores.com/ and most of the UK guys there use Sikaflex.
