Results 1 to 9 of 9
Thread: Spacers in WA - Illegal?
    Perth,WA
    Hi people,is it true wheel spacers are illegal in WA? What about wheel adapters are they also illegal?
    Thanks.
    Sep 2009
    brisbane
    Spacers/adapters are illegal across Australia unless they were original equipment on the car. Don't wanna be a douche but Google is your friend
    Perth,WA
    Man that sucks. Thanks for the reply anyway.
    Jan 2008
    Canning Vale, Perth, WA
    I believe that 10mm or less is ok in WA, but do your homework
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
    Pacific Paradise QLD
    This is the ADR Rule which applies AUSTRALIA WIDE
    4.2.2 is about spacers and adaptors
    http://www.infrastructure.gov.au/roa..._2011%20v3.pdf
    SO the answer to the title is YES they are ILLEGAL in WA or ANYWHERE in Aus EXCEPT IF ORIGINAL ON VEHICLE FROM FACTORY
    Not that it seems to stop many, going by the number bought and sold on here
    as above, pretty sure illegal AUS wide. with the exception to some cars that came with them from factory (porsche)
    Jan 2008
    I read somewhere that in WA 10mm was ok, I checked this when I fitted them to my old S#. Unfortunately I cant locate the original advice.
    however, the ADr is quite clear!
    Despite this, most modifications, including reflashes, exhausts, coilovers, lowering spring etc are classified as "illegal" but doesnt stop it being done
    Jan 2014
    pretty sure they're illegal all across australia
    Quote Originally Posted by your2dads View Post
    As I stated and linked to the ADR Rules in reply 5
    Here is the rule from the WA traffic regs site
    69. Alteration of vehicles
    (1) A person must not, without the approval of the Director General, alter a car or a
    derivative of a car from —
    (a) the manufacturer’s specifications; or
    (b) its form when it was first licensed, in regard to any part of its construction, equipment
    or fittings that was effected, manufactured or constructed in accordance with an ADR by making an
    alteration referred to in the Table to this subregulation.
    Penalty: 16 PU. Modified penalty: 2 PU.
    Table of alterations requiring approval
    Alteration
    1. Fitting an engine of greater displacement volume than an engine that was available as an
    option for the vehicle with the same braking system.
    2. Making modifications to braking systems which include the fitting of smaller diameter brake
    drums, or narrower brake drums or brake shoes which reduce the swept area of braking surface or
    which reduce the weight of the brake drum or disc.
    As at 20 Feb 2013 Version 02-f0-01 page 51
    Road Traffic (Vehicle Standards) Regulations 2002
    Part 8 Miscellaneous
    r69
    Alteration
    3. Fitting any wheel rim with more than a single weld around the circumference, or which
    does not conform to one of the dimensional standards for wheel rims set down in the Tyre and Rim
    Standards Manual issued by the Tyre and Rim Association.
    4. Widening the wheel track of front or rear wheels by more than 25 mm beyond the maximum
    specified by the vehicle manufacturer.
    5. Fitting spacers between wheels and hubs additional to any provided by the vehicle
    manufacturer.
    6. Fitting wheel nuts which do not engage the thread of the wheel studs for at least the same
    length as the nuts provided by the vehicle manufacturer, or wheel nuts which do not match with the
    taper on the wheel.
    7. Fitting tyres other than those appropriate to the wheel rim as specified in the Tyre and Rim
    8. Making modifications to an axle, axles or suspension which reduces the available suspension
    travel from static conditions to full bump position to less than two-thirds of
