this is a 165/50
http://www.tyrestretch.com/6_165_50_...otenza.jpg.php
if you want to space it out, and still have it nice and low, running 165/50's would give you no issues with rubbing etc. (re you running coilovers?)
Otherwise I'd just get a 195/50. It wont look as good, but seeing as it's a daily, and they're daily wheels, You may as well get some traction on the ground. Only potential problem could be inner clearance if the offset is rather high and you're running coilovers. (tyre rubbing on the perch/springs) Also depends on height.
Of course there are also 185/45's, and 175/50's if you want to go some where in between.
hope that helps
