Have you tried looking on ECS Tuning? They have Bilstein, Koni, as well as OEM manufacturers.
I'm hoping someone can give me a part no. or advice.
I need to replace the rear shocks on my 2009 Passat TDI sedan. In Aust it appears that all i can find are Bilstien at a ridiculous price.
Is there any other brands or a part no. for the Bilstein so I can purchase OS?
2009 125TDI Passat
2002 B5.5 1.8T Passat
Good thinkin, but how are the prices??
Thanks
2009 125TDI Passat
Have a look. Prices are good but you have to factor in the conversion rate and shipping. Most of the time its still cheaper than buying locally.
koni partno should be 8040-1352 (check for yourself).
I'm not sure what you mean by ridiculous...
$325
Koni Stoßdämpfer Sport Gelb Hinterachse Hinten 2X 8040 1352SPORT | eBay
$360
Koni Yellow Pair VW Passat 06 08 Rear Shock Strut | eBay
If the rears are gone then the fronts not far behind
$900
Koni Sport Front Rear SET 4 Shocks Struts Passat 06 08 | eBay
OEM spec Bilsteins = $250/pr
KYB excel-G = 220/pr
bilstein Yellows = $450
Try eurocarparts.com they have OEM spec sachs & bilstein for about AUD100 plus shipping (no idea what they charge).
Micksgarage.com charge $24.50 delivery they have OEM spec boge ($250) , sachs, meyle ($110), optimal ($110) & kyb
Personally, I'd go with the Koni Sport Yellows if you intend to keep the car a few years.
Ok so I checked ECS, wh ywouldnt i pick one of these?
403 Forbidden
The JOM or FK?
2009 125TDI Passat
I don't know anything about either of them.
They'll probably come in at about AUD1k
