Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Semi-slicks ... in the wet?
    Jan 2007
    I'm very close to getting a complete set of Falken semi-slicks for my VR6 and I was just wondering about other people's experience with this type of tires in general and in particular wet weather driving. I realise the lack of groves but they can't be that bad in the wet, can they?
    Jan 2008
    Canning Vale, Perth, WA
    i think it was last month's edition of motor magazine (dtd January 09) (had a mcLaren on the cover) did a giant tyre test.
    They tested road tyres, semi-slicks and a race slick all in both wet and dry.
    Its a good read and gives you an objective opinion of semi-slicks in the wet
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
    Jan 2007
    Quote Originally Posted by gareth_oau View Post
    Could you summarise the review's opinion of semi-slicks in the wet in a single word Gareth ?
    Jan 2008
    ummmm, iceskates?
    i dont have the data here, but I'll check when i get home and offer you a comparision. the difference in wet weather braking between a good road tyre and a semi-slick could mean the difference between using your brakes to stop vs using that big truck to stop
    Jan 2007
    ummmm, iceskates?
    Ahhh ok fair enough, I look forward to seeing the stats... Although I'm honestly not too surprised, ice-skates is a good word, $hit would have also sufficed...
    Nov 2006
    Ok, well i have first hand experience with this.
    This is what happened to me, mind you it was on a racetrack (Lakeside).
    http://www.vwwatercooled.org.au/newf...ad.php?t=22961
    It was drizzling and i had KUMHO V70As on, although i was contemplating whether to leave my (street)Toyo T1-Rs on or not. I decided to go with the semi slicks, and it was a bad choice. The rear end of the car just snapped out and i was a passenger the rest of the way. Ok it doesn't help that i have upgraded swaybars fitted.
    Realistically they will probably do a fair job in the wet as long as you don't push it. You just have to be really sensible when it rains thats all. Awesome grip in the dry though.
    Hope this helps to make your decision.
    '98 SEAT Ibiza Cupra Sport (track/race car)
    '05 CADDY (work/daily runabout)
    Feb 2008
    Branko, I have had semi slicks on my last 2 cars(Falken Azinis on the SRi, and I currently have Federal 595RSR's on the Polo).
    I have found that they can be a bit of a handful in the wet. You will break traction in the wet if you are too heavy with the right foot. If you are careful, you will have no dramas.
    I have found no real difference in braking distance in the wet, but if you are a bit over zealous in the corners, you will find out what understeer is.
    My biggest thing about having the semi slicks on the 2 cars has been the clutch letting go prematurely. Engine power Vs the extra grip means the standard clutch suffers. As you found the other night when I took you for a drive, the dry grip is amazing. I got over 20,000km out of the Azinis, and I have got nearly 20,000 out of the Federals, and I can see them doing another 20,000km easy.
    Jan 2007
    Thanks for the input guys, and yes I do remember how well the car gripped Ryan it felt like the tires were deflated but it was going! Another issue is whether or not I can help myself, I have always driven fairly sensibly in the wet but I might get cocky at some point. But since I own my car for pleasure and not for necessity (study and work in city) I could see myself using these tires during the regular use of the car i.e. drive when I feel like usually late at night in the dry
    In regards to the drivetrain strain, the clutch on the VR is quite firm and although its not quite as far up as I expected its certainly not going to last that much longer anyway (the car has done 72,500 km's) but probably long enough considering my relatively low usage levels and the low km of the vehicle so I'm really not that worried about it.
    Feb 2008
    Quote Originally Posted by Golf Houso View Post
    Deflated??? Sorry mate, what do you mean...I was running them at 35psi cold.
    By the way, the car wasn't running to its full potential the other night...It had 2 fault codes then, now rectified, so it feels a hell of alot better now!! It felt very laggy after the repairs, and had them cleared in Brissy on the way through.
    Jan 2007
    Quote Originally Posted by Blitzen View Post
    By the way, the car wasn't running to its full potential the other night...It had 2 fault codes when, now rectified, so it feels a hell of alot better now!! It felt very laggy after the repairs, and had them cleared in Brissy on the way through.
    I meant the lack of wheelspin, it just bogged down and gripped I haven't been in a car that did that before. It wasn't like some harder compound tire or something with alot of PSI which which just squeal and spin without really going anywhere.
    It was pretty quick when I was in it, and the semi-slicks under those conditions certainly made a big difference in your car.
