Results 1 to 10 of 14
Thread: Screwed Tyre (Literally) - Options?
    Apr 2013
    Sydney NSW
    Hi guys,
    Tyre was losing air so I took it into the local tyre joint to have it looked it. Appears that there is a screw that is pretty border line to the sidewall - which is deemed not repairable. Sent a photo to a mate who use to work at KMart Auto, he said if done properly can be repaired as these are pretty new tyres (I've had them for probably 2 months).
    Basically I suspect I have 4 options here:
    1. Take it to my mate or a another repairer to see if they can fix it.
    2. Live with having the screw in the tyre for the remainder of its life, pump it up when necessary (sounds awfully painful)
    3. Replace the single tyre with a new Pzero (Ouch).
    4. Have a pretty mint Goodyear F1 Directional 5 on hand, which as done very low KMs as well (my luck with cars have been so so) - replace the single corner with this.
    Just like to see everyone's thoughts on this, and thoughts of having a single mismatched tyre of the same size etc.
    Tyre repair is worth the gamble. Doesn't cost that much and if it sticks (I reckon 30-40% chance), money saved. Otherwise, it was a reasonable gamble with very minimal loss.
    Or if you're like me, buy cheapest chinese tyre, put it on wheel that gets most of the power. Replace 2-3 times until the rest of the tyres catch up. Victory for all!
    "Dying 's for fools ... ... Because, because I'm a man." - Charlie Sheen
    That tyre looks like it's only done very few kms .. OUCH indeed.
    My guess is the other 3 are in very good condition too ?
    I'd do option 3 but I won't be happy about it.
    RS
    R
    Dec 2008
    Sydney/Canberra
    At the risk of a complete structural failure, I'd replace the tyre.
    It's too close to the sidewall to repair, in my opinion.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Apr 2013
    Sydney NSW
    Thanks guys, I'm leaning towards replacing the tyre also after getting a better picture this morning.
    Can someone advise of the downside of option 4 - mismatching the single corner with another branded performance tyre.
    Jun 2007
    Quote Originally Posted by Umai Naa!! View Post
    I'm with you Umai, sidewall failure can have catastrophic consequences.
    Question to the OP is, what is the price of replacing a tyre compared to the cost of not replacing it and a failure causing a major accident? It's a no brainer to me, no suspect tyre is worth the risk to your or someone else's life.
    George
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
    Pacific Paradise QLD
    Have had tyres with small holes like that patched with a sleeve vulcanised inside As long as the threads are not broken which is what makes them unsafe and prone to a blowout. Would only ever use it on the rear and preferably only for a spare
    Dec 2008
    Sydney/Canberra
    When you enlarge the hole to pull the tread repair insert through, you break through the cords anyway.
    However, the closer to the centre of the tread it is, the less of an issue it is.
    '01 Beetle 2.0
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by pandas View Post
    Depends how worn the existing tyres are.
    Although, I'd be leaning towards getting the same tyre as the others, if possible.
    '01 Beetle 2.0
  10. Quote Originally Posted by pandas View Post
    We do this with my wifes evo all the time. For some reason it is real prone to punctures. It has the same brand and wear on the rear, with an additional two brands at different stages of wear on the front. Is awd and is beat up badly, so we probably wouldnt notice much difference anyway.
