Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Rounded wheel bolt
    Pacific Paradise QLD
    Quote Originally Posted by pat_00 View Post
    I've had this happen to a car in the past. Local tyre shop was able to get it off by air-chiselling the edge of the bolt on an angle that turned it counter clockwise. Was a bit scary watching this, but it worked fine.
    Butchers. A decent tyre shop would have a set of Ease out sockets that grip in an anti clockwise direction and simply undo a rounded nut. If a guy in a place like Tennant Creek had one why wouldnt a big busy tyre shop in a city.
    I had an 84 Telstar that had fine thread studs and a tyre shop did them up too tight Broke 3 getting them off and cost me a new set and a front wheel bearing as it gets damaged when removing hub to replace studs.
    Was no other way apparently
    Jul 2011
    South-East Brisbane, Queensland
    SO, went to two tyre shops and finally called thread tech. Here's the results
    BIG shout out to these guys! Had to use a massive ease out socket with a breaker bar and about 3 long pipes on it for leverage haha
    Dan!
    v5 Bora/Indigo Blue/Remus sports exhaust/JOM coilovers/Lots of DIY bits and Pieces/
    Mar 2013
    Brisbane QLD
    glad you got it sorted Dan...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
