Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Rims for my golf
    Erskineville, NSW
    Quote Originally Posted by MickeyTDi View Post
    Thanks for the really good advice guys. REXman im with the nrma and i didnt know that so thats something really worth knowing.
    It's actually an RTA thing & it's open to interpretation. You could say +2 on what's fitted; +2 over the largest diameter wheel shown on the fuel flap; or +2 over the largest wheel fitted to the vehicles as OEM (eg: 18" like on a GTI +2 = 20").
    IMO, if you have 15" then I wouldn't bother with more than 17" anyway - 17" tyres can be had at a reasonable price.
    @ converted and brad if you have some links id really love to check them out =D
    just look on ebay and type something like Golf wheels or volkswagen alloys & have a browse.
    These
    or these
    or maybe these
    or (shameless self advertising) these
    or keep an eye on these but $550 is way too much for 16"
    and Manaz is there any way of getting the speedometer sorta re done to calculate the actual speed of the car once u put bigger wheels n tires in? im on my red Ps and speed is something ive really gotta be conscious about if i wanna keep on driving my car
    I don't think you get it. You change the rim diameter but keep the overall diameter close to the original & then your speedometer stays constant & no adjustment is needed.
    What size tyre are you running at the moment? 195/60x15?
    Also have you checked the accuracy of your speedometer against a GPS?
    Apr 2008
    Use the calculator already linked to to keep things as close to correct as possible by lowering the profile as you increase wheel size (for example, my car came with 16" wheels and 205/55R16 tyres, I'm on 17" wheels and 225/45R17 tyres now and the rolling diameter is practically identical). A good test of how accurate your speedo is at present is to test with a GPS unit.
    Nothing to see here...
    Oct 2010
    Homebush, NSW
    Ok yeah i get it now. Thanks again for the advice guys. I dont have a GPS :S i only just got the car about 2 months ago and ive never needed a gps however when i eventually do upgrade ill be sure to make sure everythings kept legal size wise and also everythings in order to do with speed readings as well and if im not sure about something im sure whoever ends up fitting it will know a thing or 2 about whatever question i have. If not you guys seem to know your stuff Thanks again everyone
    Oct 2010
    Homebush, NSW
    Speedos on the newer VWs is so far out its not going to make to much difference, as manaz said, run you stock set up (tyre size and wheel size) through the calculator along with your proposed setup.
    for example, i went from from stock 15s to 18s with the suggest tyre size (195/65/15 to 225/40/1 and it was slightly bigger so made the speedo slightly better.
    Wheel / tire size calculator / comparer - RIMSnTIRES.com try this calculator, i find it good for normal fitted tyres, tells u how much your speedo will be out etc
    May 2010
    WA
    Quote Originally Posted by Converted View Post
    While browsing last week, I came across a manufacturer that does a matt black Denver/Detroit looking rims, if you are after this kind of design/look.
    I'll need to check my home pc for the link tonight.
    Here you go mate...
    Alufelge PRO 5 Nero 3.0 - PROsport-Tuning Felgentuning
    These are copies of the Detroits/Denver in matt black by ProSport.
    They've similar rims to the R's as well.
    I wonder if ProSport supply rims to VW(?).
    [MK6 GTI MY11 CW 3-door DSG Sunroof Detroits Dark Tint R LEDs APR Stage 1 (regrettably a few years late)]
    Erskineville, NSW
    you haven't got a friend with one that you can borrow for 30 minutes? Or an iphone or one of those other smarty-pants phones?
    Oct 2010
    Homebush, NSW
    well as i havent done anything to the car yet i havent really needed to test it out but yeah i can borrow one
